SnowDrift
Ultra Conservative. ULTRA!
I read through some content and found a pretty in depth conversation about the fan clutch here:
I like the idea of electric fans, but I'm just not sure it's a good fit for me right now. It could be in the future, though. I have the single thermostat crossover.
What is a good choice for water pump? There are a couple types offered by vendors here and there is also the later HO style. What is recommended?
Right now, I have the bolt-on type (4 bolts), but can change to screw-on if that is better. I had in mind to at least convert to the Duramax fan.
6.5 over heating
Water wetter works. Been proven time and again in testing. There's a reason why racers use it - it aids in the transfer of heat from block/head metal to the coolant and from the coolant to the radiator metal because it's a surfacant and that helps the engine run cooler.
www.thetruckstop.us
