Rodd
Recruit
What kind of ridge do you have? A deglazing tool can quickly knock the carbon build up off. Ridge reamers are dangerous to remove just carbon. Remove bearing shell and block of wood to hammer rings past carbon build up. If the wood splinters you have too much buildup.
The cylinder that I am taking the first one out of has the least amount of carbon on it. The cylinder walls don't have any carbon on them up to the edge, so I'm not sure if the deglazing tool will do anything. I will try with a block of wood.
