Will L.
Parts stores sell aerosol can that you just put inside the supply side line and have the return line just go into a drain pan. Slip the hose in and wrap with a little duct tape to seal a little bit. Push the button until she is empty.
I usually do that then just shoot a little att through it afterwards with the air compressor.
I have seen people flush with couple new quarts of atf, but thats just as expensive and doesn’t clean it out as well.
