@Husker6.5 out of those brands what's the recommendation?. And what brand hoses?...I'm assuming I can get all the parts from Rock Auto.Well, you know the general consensus of all the serious wrenchers on here about AZ and their parts - any kind of parts.
When it comes to brake parts I will only use new, OEM or aftermarket upgraded calipers or name brand remanufactured calipers (like Raybestos, Borg Warner or AC Delco) as there's too much on the line to use housebrand chainstore parts or generic.
Yeah, IIRC the drum widths are the same and the difference is in the shoe width, the SRW being like an inch narrower than the drum, the DRW shoe the full drum width. The nice thing is that Rock Auto does show all the differences between 3500, 3500 DRW and 3500HD DRW applications for both the front disc and rear drum brakes.on the wheel cylinders ,there is a larger bore wc which is what you need. also measure the width of your rear shoes and then measure the width of the shoe surface are in the drums. they should match with maybe a 1/8 -1/4" difference.
Was looking at rock auto...they have reman AC Delco calipers, the hoses aren't bad prices..
Another thing I noticed..the other day I checked power steering fluid it was really low.. the steering usually feels ok but at times can be a little choppy or feel like power steering not working good . But that doesn't last it's intermittent..
Also (since power steering is part of the belt drive)..I can put a brand new belt on , tensioner sitting right in the perfect zone, and within 20 minutes of driving the belt is stretched and tensioner is at full extension like you'd expect with a worn out belt. Only mentioned it cause power steering pump is hooked to the hydro boost so I assume it all effects each other
