dkanderson
PMD only controls the fuel solenoid of the IP has nothing to do at all with the lift pump & glows, problem is nobody more qualified than yourself with help of folks here to work on the 6.5 anymore, GM techs will charge you big $$$ for the things we are working through with you,
Few dealerships aka Stealerships have a good Diesel tech on staff and unless they have been around a long time all they know is the Dmax Diesel, and apples to oranges differences between the two setups
Yeah i didnt think the pmd did any of that, ive been doing some reading about this and do you think it could be the oil pressure switch? i dont know if it controls the glow plugs but ive heard it controls the lift pump, other then that im still kinda lost on the whole deal.
Also the ground that comes from where the tranny dip stick is, It goes down behind the motor and grounds to the frame do you think that maybe when its getting hot back there its shorting out or somthing, if so what would be the best way to get that out cuz u cant get the dip stick tube to move up the bolt at all, i guess i could cut it to get it out.....
Also would a bad water temp sensor make it shut down? cuz im still waiting for my new one to come in, just trying to rule everything out so i can get closer to the problem.
Heads up to everyone if u need a new injection pump you can get a brand new one at orellys for $300 and a rebuilt one for $150 just found that out today
