packratt
Active Member
Weekend before Christmas went down to TN to visit my brother. When I got there the coolant low light came on. Drove about another 250 miles light on. Another 250 light. I've had the truck for about 30,000 miles and heater has always had some odor also had to add the reservoir full about every 6 months. Never overheated and oil analysis has been good. I assumed heater core or water pump had gone bad. Drove it to work the next day because car was in shop and on the way home I got the great big cloud of white smoke that we all know and hate:mad2::mad2:
Bought one of those tarp canopies with sides so I could have the truck out of the weather and heated.
Since the truck had never overheated to my knowledge I was hoping it was just head gasket. Bought a Magnaflux Spot Check Kit (Granger had the best price) wasn't cheap but cheaper than a set of headgaskets if I had reassembled on a bad block. Pulled the heads. Gasket looked fine, OH S*&@. Took heads to machine shop to be tested and rebuilt if possible. Got home and proceeded to test block.
Ran the test and started cussing. I hadn't used the stuff before so I took some pics (bad lighting poor quality) and sent them to a buddy who does NDT and DT for a living. His response was
Had 4 cracks in 8 and 1 in 6. Didn't bother to check the other cylinders.
Before anyone posts this sticky :nopics: DON'T in a couple days when I have the block out and can redo the penetrant test in good lighting I will take pics of the carnage and post.
YEP!!
That's a BIG CRACK!!
Doubtful if there is ANY FIX . . . . .
Sorry, Bur now you know for sure.
