bfourman
Looks nice! Don't forget to put your steps up before hitting the road or you'll add those to the to-do list
Hey stop @ Mabry Mill on the blue ridge parkway and get some stone ground grits! They r awesome and take a pic of the still for Ace!
I know my father in law is a retired a/c refrigeration guy...and he's already told me I/we should install a hard start on the unit...I'd be hard pressed to get a 2000 even with the hard start installed, because you are limited in what you can run in addition to the A/c if your are limited to a generator only power supply...
on edit I have heard nothing but good about yamaha's generators...and it looks like they came out with an in between model...
a 2400 that weighs only 75#
http://www.yamaha-motor.com/outdoor/products/modelspecs/475/0/specs.aspx
Glad to hear you're going to make it...
I have a question for you ferm since you seem to be really good with this stuff...
My rear tube bumper that holds the sewer hose tore a little on the pass. side at the top where the frame rail welds to it...
I have a curt hitch on the tube but never towed with it, but have a hitch haul with just the kids bikes on it and also the spare tire is mounted directly to the tube...
there are no signs of it being corrosion related...so I'm guessing it's a strength issue...
any idea if there is another thicker walled square tubing that will still have enough inner diameter to accept the sewer hose into it...it still has to be 4x4 because the curt hitch's u bolts have to go around it and line up with the hitch bolt holes...
just looking for ideas really other than maybe bringing it to a welding shop and have them fish plate the bumper in the area where the frame mounts/welds to it...
just want it to be strong, cause I'm seriously considering toting a generator on the hitch haul for long trips for the dogs sake...
