great white
Today I fixed the cargo light. It's been out since I bought the truck and has been bugging the heck out of me. It's not something I've had a use fro, I just can't stand having something on the truck that doesn't work!
Had to melt the plastic in the bulb housing away to find a corroded strip from the pin to the lights and solder in a jumper.
Bumped out a couple dents in the extended cab while I had the interior out chasing down the snag and "rust killed" some beginning rust inside the panel and cab corners.
Also spray foamed the double skin roof on the passenger side. The annoying metal "ring" noise when you slam the door or tap the roof panel is gone...
