great white
Very happy to report with the new tools an IP adjustment now takes about 5 mins. That's with removing the engine cover and upper intake. The fabbed wrench fits nicely on the driver side nut and the upper intake. The angle is just a wee bit off to do a good job on the passenger side but I have a 15mm flex head gear wrench on order that will do that job nicely.
I'm now sitting at -.35 for tdco. I'll run that for a whiel and see how I like it. Truck seems quieter already with no real noticeable diff in power (not by the "butt dyno" at least).
Once the flex head gets here, All an IP timing change will require is disconnecting a few electrical connectors (for room to move) and hooking up the scanner. Nothing else will have to come off.
Life is good....
Life is good....
