This truck was intended to be "bought, not built".
It's got the 5/100,000 warranty on it right now so I'm not touching it other than clean and wax. That's the "premium" warranty. 0 deductible and covers everything besides stuff like brake pads, oil changes, coolant, and tires. Even stuff like ball joints and tie rods are covered. I may even kick that out to the 8/200,000 in a few years. Dunno yet. Lots of time to make that decision.
There's nothing I would really do to it anyways other than maybe some 3m clear rock guard, weather tek mats or the like. It's getting a Ford accessories tri-fold hard tonneau cover from the dealer (part of the purchase negotiations).
Like I said: I bought what I wanted, I didn't want to build it.
I want something nice to drive and not a project. I'm too busted up from work ("forced" into early retirement at 51, not complaining - benefits are good enough I don't have to work if I don't want to) to be freezing on the side of the road waiting for a tow truck or lying on a snow covered driveway in -5C trying to fix it. This truck is the last one, as long as it doesn't get wrecked or turns out to be a lemon. Keeping it at least 20 years if i get my way.
This is my project for retirement:
1983 Mustang that I bought new in 1983. Originally a V6 auto. Ended high school in it, went to university in it, first marriage in it, daughter from the hospital in it, first divorce in it, etc...
Done or in progress:
Body;
87 GT lower body work, front grafted to 83 nose. Fog light holes will be for brake cooling ducts
87 GT rear "wing" (oem one)
83 GT hood scoop
83 T-Top roof
Assorted rust repairs
Full length subframe connectors with seat tie in
Rocker/jacking rails tied to the subframe connectors
Engine/transmission;
89 302 roller block, stock internals (IE: E7 heads, forged pistons, etc)
Stock cam
Edelbrock Performer RPM II air gap intake
Holley 750, vacuum secondaries
BBK Longtube headers, BBK H pipe, Magnaflow SS cat back exhaust.
1996 V6 T5 (same trq rating as 86-93 v8 T5)
11" clutch and pressure plate
Rear end;
8.8
3.73 gears
31 spline Trac lock differential
31 spline axles (Yukon brand, sn95 5 lug)
Mark Williams engineering bearing caps
Aluminum cover
Brakes/spindles/steering
1994 SN95 spindles
2003 PBR twin piston calipers (front)
1997 SN95 Calipers (rear)
1995 SN95 GT master cylinder, booster and prop valve
Stainless steel braided lines
SN95 Steering rack (15:1, improved road feel and power boost)
Suspension- Front:
Modified K member, slid 3/4" forward, engine moved 1.25" back
2003 Cobra lower control arms
Low friction ball joints
2003 Mach 1 springs (600 lb rate)
Camber/caster plates
Bilstein struts
Suspension- Rear:
Bilstein shocks
Maximum Motorsports panhard bar
Maximum Motorsports Torque arm
Maximum Motorsports lower control arms with height adjusters
2003 Mach 1 springs (250 lb rate)
2005 Mustang "Bullitt" rims
Lots of other little bits, but that's the "meat".
Like I said, the car is my retirement "toy". Used for wrenchin', cruising and some autocross style events. Autocross is just for grins and giggles, I have no intentions of being "competitive".
We're kind of looking to sell the travel trailer off, we just don't use it enough. If that happens, I'm going to get a covered car trailer to haul the Mustang around. That way if I break it at an autocross event, I just load it up and head home rather than trying to figure out how I'm going to get home. It can also haul my "VMaxed" Yamaha Venture and FJ1200 when/if we have to move (wife still working).
I may stop by from time to time, but probably few and far between...
