great white
Mr postman brought me some presents today. Had to rush out and get them installed so I could see how it looks:
(apologies for the washed out pics, the garage door was reflecting a lot of light)
Now, how it looks is a subjective thing and is different for everyone but I like it!
The door wood just snaps into place, the steering wheel is not a bolt on though.
The hub is bigger on the GMT400 column than the STS. I had to enlarge the hole and re-manufacture the splines including the master spline. I also had to create a hole in the aluminum structure to fit the horn wire through.
Next I need to build a center section to cover the bits.
After I get the clockspring in my hot little mitts I'll get to work metering things out and incorporating the radio and cruise controls, eventually setting up the wheel heat and bluetooth button.
Now that I have the wheel and inserts I can figure out the best match for the center console wood insert and get that done also.
I really, really really like it so far and that wheel feels great in your hands. Smooth, well shaped, comfortable and just a great fit!
That's probably it for the wood though....it's just enough. Any more would probably start to look a bit gaudy....
