great white
All I've got for pictures right now. Folded and in the support mount I built:
That's the middle of the roof in width and length and about 10 inches forward of the center of the whole truck.
The mount is just a cheapy for now:
Good enough for barefoot. I'll probably eventually order a Breedlove fold over mount when I start to run some power through it.
It'll be about a year or so before I even get to installing my little TS DX250 Amp. I'm getting ready to move across the continent and I just don't have any more time to give it right now.
The roof panel moves around a bit more than I wanted behind the mount. The mount is right up against an internal support beam, but the back half of the beam is pulled away from the roof skin. I plan to shim it and reapply the panel adhesive for now. I might switch to a bigger mount later, but I just don't have the cash for it right now.....
The CB power and ground goes directly out to the drivers side batt terminals. The Dist block also goes to the drivers batt, but they only share the terminal point. I ran the 4 gauge for the distr block because I already had the electrical apart underhood and was drilling pass through holes in the firewall. Was easy to drill, grommet and run the wire for one more hole at the time.
The CB has it's own separate Hella 40A relay out under the hood.
One thing I have to do is install a fuse for the CB power feed up next to the batt, the glass fuse down by the radio doesn't do much if there's a short underhood.
Powered up my cobra 29 WX NW BT today for the first time......pretty little thing with the blue back lighting and all...
I also ordered up a Uniden Bearcat esp20 20W external speaker to mount in my overhead console, seeing as my Cobra 29 internal speaker in now buried face down in the carpet (hehheh, face down in the carpet, hehheh)....
