great white
Oddly enough, I was thinking about relocating the FSD again just before Leroy posted, for much the reasons he listed (impact, rocks, etc).
I'm also somewhat concerned about water immersion (Umm, What?!? did he just say IMMERSION!?!) in that location.
I do believe I shall locate the FSD here:
It might be off to the left or right a bit, it will depend on the space available once I measure it all up.
Still in the airflow, out of the engine bay, high enough that water immersion should never be an issue and reasonable protection from rocks/ road debris. Should I ever get into an accident and the FSD gets damaged there, I'll have bigger issues to deal with than the FSD...
It will fit in nicely for my plans to make a support for the middle of the plastic grill where it sags slightly, just so I can get the panel gaps right.
I'll just adjust the manufacture of the bracket to make a spot to mount the FSD. The bracket will also be a heavier gauge steel, so the FSD should be adequately supported from vibration.
Now that I think of it, I may rubber mount the heat sink/FSD combo to further reduce vibration.
Shouldn't take much more than a couple hours to fab up a bracket. Biggest PITA will be I'll most likely have to redo the extension wiring as I don't think there will be enough length to reach....
