ak diesel driver
6.5 driver
mech brake control? never been around that brake controller before
Good job, when I came up with the FTB idea a few years back at Diesel Page then Place a number of folks scoffed at the idea.
To me it just made sense climbing a hill with a load, push the go pedal all way to floor, and vehicle does not speed up, EGT does not go up, boost holding at 10 psi and yet I'm just at 2700 rpm, should be more go left in the engine or I should see temps & parameters climbing to meet the demand; so I installed a test gauge and lo & behold I'm seeing 0 psi at IP inlet with a reasonably new lift pump, did the FTB and I got the lost performance back.
Well I'm glad to see another satisfied 6.5er that benefited from the concept, did you also open the 4 holes in the inlet fitting I assume you did since you took off the fuel shutdown solenoid.
Nope, didn't feel the need to go in that deep.
I just wanted sure and steady pressure and GPH available to the injection pump.
I think I got it!
120 bucks at the local jobbber :sneaky:
Dropped in today to pick it up and sure enough, wrong part. Never seen it before in my life. Some kind of electrical switch with a rubberized primer bulb on the end of it.
NIB Stanadyne ESO, P/N 3072, 85 bucks shipped to my door.
Sometimes, eBay ain't so bad to have around.....
Possibly the part listed was the one for the DB2 IP your description sounds like the one used on those.
2 styles for the DS4 both are cylindrical one has a Allen screw in the end (old type), and newest one has the wrenching hex flat boss in the end of it, both interchange, but the older ones with Allen are prone to leak where the Allen threads into the body
