vdb11
Halfmoon Detroit #2
Well 6.2 turbo, I gave it another go today with no luck. I tightened up the governor spring and put it in the new pump. When I had the pump in, I blew air into into the inlet at the back of the pump (about 80 psi but I couldn't get a good seal). I then cranked and cranked and she wouldn't fire. So I pulled the fuel line and blew some more air in and tried again with no luck. So I can only think of three things:
1) Loose plungers letting fuel by
2) Plungers are still stuck
3) Delivery valve adjusted too tight and not letting fuel by. The PO of the pump said he did not mess with the delivery valve screw so I didn't touch it, especially since I don't have any way of getting the screw torqued to the right spec.
Anything else I could have messed up? Anything on the top end?
Any help is appreciated. If I can't get the pump running tomorrow or monday, I will pull the pump and probably send it to a pump shop so that they can at least determine if the pump will even pump fuel.
Thanks guys
Thanks guys
