Acesneights1
or a bolt you may have forgotten to tighten on the clutch assmby....Hmmm...Did you check your aircleaner studs ?
uh-huh... sounding like you need to go loosen off your injectors, one at a time, like Kenny suggested.
And put BIG blocks around your wheels...
If the truck rolls over you, we want pictures!
It's no fun getting run over by your own truck...Ask me how I know. The brown one in my photo album ran me over with the plow on. Heating Oil will not hurt the engine. In fact aside fro legal implications , it's actually better for it.
You may have lost a rocker arm button on that side.
Krrp us posted
A rod knock will most generally be associated with a loss of oil pressure too especially at low speeds HOT
The pistons in these come to within about .040" of the head, so the loss of a bearing can cause the piston to smack the head too.
A rod knock will be at crank speed, is your "TICK" at crank speed or cam speed (1/2 crank) ??????
Does the engine run smooth???
A rocker button thats failed and allowed the rocker to slip off the valve will cause a miss on the cylinder involved and also a nasty shake.
Rod bearing failure is a nasty hard thuding noise that will not usually be heard up top.
First tell us if the noise is at cranks speed or ccam speed.
Missy
If the engine has/had been apart and the pushrods installed backwards they can wear quickly and then cause a lot of noise.
The pushrods on these engines are a direction specific part.
One end is hardened and it is colored a copper color, this end goes to the rocker.
Many times these get installed backwards.
Missy
