Acesneights1
Turning wrench I might take a whack at. we got welder and torches. The ip wrenches might be worth the 80$. They will get used more than once
Not yet. I try to save bugging him till I'm at my end which I think I am. Yeah the pulse width did and what's better it that all the way up 3000 rpm it never went over 2ms so that's a good thing right ? Thing I don't get is when you turn the pump what am I actually changing ? The TDCO, The Desired ? The actual ? This is where I am confused.I used an oil filter wrench (pliers style) once I had the nuts loosened.
It is a small margin you will be rotating it to the driver's side 1 mm.
Your pulse width got a bit better.
Did you PM jd?
I PM'd him 6 posts ago.:hurray: Actually I think I'm getting it. The factory GM Manual has a really good section on it. If I'm reading it right it basically sets the measured to 3.5. The whole TDCO is called backup timing procedure.Sort of like a secondary way of doing it if I'm reading it right. I am chipped. Heath V2Get jd to weigh in on this. His info can only add to the site....
Thanks Leo. My 95 is a single T. Maybe I'll eyeball it tomorrow before I spend 90$ on wrenches.I bent a cheap 15mm wrench for my IP wrench. It works fine on the single T-stat but may not reach on the dual T-stat motors. Leo
