ak diesel driver
6.5 driver
Will's gonna have to build a roll cage for his rooftop radiator.
On the flats (up to 2% short-ish grades) it is holding temps fairly steady with the RV in tow at 55 mph. No A/C for that trip.
How did that compare to before?
So, I changed the oil and filter. When it drained, I did see a bunch of water come out.
. . . fell asleep exhausted from dealing with all this and at 3am, my eyes went doink! Wide open. I was hearing Wills booming, godly voice saying "Wmi system failure more likely you silly Jack-ass!" And he looked just like Morgan Freeman wearing a Popeye the sailor man onesy and holding a giant Ar-15 which was strangely comforting and disturbing all at the same time.
A lot of alloy cages in many sizes for roof top accessories via military surplus out there too.Will's gonna have to build a roll cage for his rooftop radiator.
You want to put a valve on your WHAT?? That sounds painful.OMG! I somehow missed that part of Hinks post finding the leaking injector of the Morgan Freeman thing until Jay quoted it. Im not sure how that picture looks. Morgan Freeman in a Sailor suit? Booming voice? I get the feeling I use my sarcasm font too often- haha. So focused on the water droplet I must have been in shock.
The leaky WMI is absolutley the scariest thing about it. Im willing to bet 99% of people that dont have wmi - thats the reason. I've ran systems on hot rods, but still haven't put one on the hummer because theres no such thing as a lower mounted water tank in it. The valve as a secondary safety is all i will have, so i haven't pulled the pin on it yet. If i could mount a mechanical ball valve next to my ignition switch...
Let us know how that works out!The better test will come when I hit the 5 mile long 5 - 6% grades with the A/C 'On'.
IF the water is all blown out, why would it blow? Or are you saying before they blow the water out?Diesel drivers are not always so lucky as it is not uncommon for the motor to blow a hole through the block when it ingests a mass of water through the intake.
I can see that. The Devils own Solenoid that sctrailrider suggested would solve all that though. Or maybe @Burning oilIm willing to bet 99% of people that dont have wmi - thats the reason.
I totally agree with that. The thing I like about this system is that you can just ignore it if it goes haywire (or remove the injector like I did). The engines normal running performance is unaffected without it hooked up.I see it as added complexity and a maintenance item.
I am definitely planning that. I already have the gauge installed, I just need to wait for an opportunity to get the probe installed into the head at #8.you may consider installing an aftermarket gauge and temp probe.
While I don't expect it to be bulletproof, I do expect the optimizer engines with the heavier deck, moly added to the block casting and head improvements (flow and Chromium added, I believe) to be able to take the heat better than the GM versions. Do you still use the 210* mark as your limit? Are you able to ALWAYS prevent temps from ever getting above 210?The only thing I back off for is ECT getting out of control.
I never could get a clear enough shot at the date code to see manufacture date but I do know that later model optimizer engines were a lower compression and I used .010 gaskets to get it down lower. I'm at maybe 19:1? Still high though, I know.Gas engines don't run at ~21:1 compression.
Around here, tropical storms (former hurricane) roll through every few years, flood roads, friends try to drive through the new moat around their community, and I pull them out. First things we do is drain the water out of the oil, pop the spark plugs and crank the starter a bit to blow the water out, and then start the motor. Diesel drivers are not always so lucky as it is not uncommon for the motor to blow a hole through the block when it ingests a mass of water through the intake.
was the water cold?Not me, I would never take my hummer in the water.
Defenately not deep enough one time that it came in the drivers window with it rolled down.![]()
