DieselSlug
I would say replace them. That oil pan has been jb welded about 6 times....):h
Clean the pan off to bare metal,and use POR-15 paint on it.It'll last a 100 yrs,
You guys could just keep adding turbo's to your engines. Everytime you spring a leak drill a hole in that spot for a turbo oil drain.
GMCtrk:
You texas/southern boys think this stuff is funny don't you!!!!! I sure wish my metal would last forever too, and everybolt just magically unbolts like watching speed-tv or shadetree mechanic....
Are all the oil pan screws the same? I'd like to replace them as they don't look to good.
Or the 2 rear different, then the rest the same? Can't hurt to pull one out and go to the store and put it back in I would think.
I actually had your new pan in mind for thisIf i scraped it all down to bare metal, i'm not sure what would be left for the por-15 to bond too. Perhaps itmight seal up Dieselslugs though. Mines just too rusty crusty up there. Stinks without camera.
The 2 rear are different. They are a little bigger. Mine were metric but I don,t know when the switch over was. I had to drop mine over the winter and I also dropped the differential. You may want to find a cheap source for a gasket if you don't have one. They don't have a gasket from factory, just rtv but I ripped the rear rubber seal trying to get it off since it was rtved to the pan.
Here is one for the 6.2. It doesn't show a seal for the front cover to pan, so I don't know if there is one or not.
It also doesn't show the bolts which is specifically what I'm looking for.
From everything I've read (and I've read alot of search threads over the last day) 'Right Stuff' from Permatex is the best available sealant, and the only sealant needed for this job.
As far as torque specs go, I don't have a inch 1/4 drive torque wrench, should I buy one? Or is 'snug' good enough?
The one on right is the rear most oil pan bolt. One on each side. It is M8X1.25 and about 20mm long
The hole in the block (on Mine) go's into the bell housing area (meaning you could use a 2" long bolt there if needed)
The smaller one I don't know the size.
The front of the pan bolts to the timing cover, so no rubber like the rear.
