Difference between the two is size, Turbine Doc has both as he has both boxes in different rigs. He told me he was pleased with the improvement in air flow over a new stock filter element. The larger filter will not fit in the smaller box, the lid won't fit.
Yes, Donaldson is the manufacturer of the media and these filters do very well in this application. I'll see if TD will chime in here with his experience.
$60 is the retail price before shipping and tax, I give all members a substantial discount. PM me with your zipcode for a quote.
As you can see from that picture mine says it takes the A1300C or for severe dust use the A1306C filter. The A1306C is the bigger filter and if it didn't say it on the box I would think I had the wrong one because the bigger filter makes it very tough to get closed.
Yeah I put the smaller one in mine. I would think the big one would starve for available air. Filter would basically be touching the box in most places.
HighSierra where did you get that sewer pipe fitting? All I could find was a schedule 40 90. On one end it fit my stock turbo hose perfect at 4" OD but the other end was only 3 & 1/2" OD and needed to be about 3 & 3/4" OD to fit tight in the filter. I went ahead and installed the new air cleaner with the turbo hose that came with it but would like to find the less restrictive 90 and use my stock hose.
When changing my glows today, I got a closer look at the airbox. I'll be going with the smaller filter. I would think the bigger one would almost cover the fender hole!
When I try to stuff the big Amsoil in the air box that is what happens, no clearance either side of the air box & lid does not close, the smaller one fits perfectly.
