- Staff
- #81
I removed all the left over spray foam that was sticking out. I also reinstalled the thin foam.
Put some more siding up across the back. I put the two small sections of siding up on both sides of the window.
I taped up and finished prepping the thin foam for the siding to go back on.
I then installed the siding that runs around the bottom of the window.
Then stuck the window back in. It is only sticking in there. I still need to screw it back in.
The rain got below the generator box. There was a small puddle of water underneath it. It also turned the sealer white.
I hope this does not cause me any problems. :mad2:
Installed more siding. My camera does not like my shaky hands at night.
This one was giving me trouble because of the jack plug.
More siding up. Two separate small sections.
One more section of siding.
Here is the last siding section going up. This one is just stuck up in there. I have not stapled it in yet.
It is suppose to rain here again tonight and tomorrow. I was trying to get what is still good covered up.
I still need to get the butyl tape before I put the outer edge up.
