vstech
Wow...
Assuming this gets assembled... I've been following the thread a WHILE...
How long to INSTALL the motor?
Wow...
OH ok, I don't have one of those, but do have a crank key.Offset key to finish degreeing the cam
I was thinking House Key?The key of D Minor!
Hey Leroy, y'all building a 6.5 turbo ark down there in Houston?
I can't to see when it's running, I'm sure it will be awesome. It's a good thing you were able to get the existing engine running right again.I would assume that also. Considering Chevy used a ton of parts that will work on virtually any gas v8 of their's, especially small block to small block and big block to big block, I would assume a 6.5 is no different. The only thing I have noticed in looking for a key is that there were two different types of keys they've used over the years: a short one and a long one. So I would guess if the length matches then so should the other measurements.
I didn't think about going to a parts store and comparing. I have a couple cranks sitting around, maybe I'll pull a key out of one and run to the parts store and compare. [emoji1303]
Someday, just maybe, I'll have this thing together.... Hopefully it will run when it's all said and done lol
Got a link to the key your looking for?
