Rodd
Recruit
The hole looks to be 3/8 - 1/2. It's slightly smaller than the 5/8 oil cooler line holes.Most likely a 1/8th inch pipe plug.
Sometimes there was an oil pressure sending unit installed in that location.
Since the oil cooler holes are NPT would that be NPT as well?I wonder if that is where a stud for the clutch linkage tube would have screwed into.
If a 3/8ths or a 1/2” NC bolt will fit the hole, then that most likely will be the case.
That's where I tapped in for the engine oil bypass filter on the first 2 - 6.5's I did.Most likely a 1/8th inch pipe plug.
Need to look at the threads within the bore, compare those to what pipe thread looks like.Since the oil cooler holes are NPT would that be NPT as well?
Well we may have a problem.
We're any of the plugs nps?Need to look at the threads within the bore, compare those to what pipe thread looks like.
If You have a proper size piece of pipe, or a pipe fitting with the same size as that bore, see how it screws into the hole.
That I do not know.We're any of the plugs nps?
Thanks! That's what I thought.The 95 I did was 4WD and had the tabs to the rear that would mount the support bars for the conv cover .
Thanks! Got it almost done. Just need to double check all the grounds, wiring, install the radiator and starter and she should be ready for her first start.Check my signature line - you might be able to see what you're looking for in the link.
