hookedup50
Active Member
I’m going to continue to look for chafing, and let it sit till right switch arrives. I should continue stitch welding the lower cab panels and vacuum the leaves from yard.
I’m a watchmaker, I didn’t consider using broaches and tiny filesLook for root canal files.
Tiny little files that can get into the smallest electrical terminal connectors and scrub them out.
Several years ago I went through every terminal and blocks of terminals that I could get my hands on, on My 2000 K3500.
As I was scrubbing connectors I’d give each one a light smear od Truck-Lite compound. An anti corrosion salve that does a real good job.
