hookedup50
One last point, the internet is littered with these posts, and nobody ever admits what was wrong.
And then a thread for a fix will be advancing along then some @ss hole will post, sent you a PM and that ends any more of that fixit thread.One last point, the internet is littered with these posts, and nobody ever admits what was wrong.
I could not find that 30R9 rated hose at the two parts stores here.It all depends on the mixture they use.
Ideally-replace all the rubber lines with sae30r9 then never worry about it.
I built a bracket that raised up the FFM, then turned it 90* CCW. In hose then came in from the passenger side and outgoing towards the drivers side.I re-routed mine to go over the top of the intake. at first I had re-located the FFM so that the hoses weren't under the intake and in the valley just by raising it up some. later I completely eliminated the FFM and used a filter with clear bowl mounted on tthe firewall. doing this also depends on your area's climate if you need a filter with a fuel heater. here in Texas it doesn't get cold enough to need one and once the engine compartment gets warm I can still drive into colder climates.
the plus on removing the ffm from that area too is you gain access to where the ops is and other tid bits in that area. iirc Leroy also sells a harness that allows you to connect to the factory ffm heater and wif connectors and run them just about anywhere under the hood. when I bought my 93 it had this installed and the FFM was sitting on the drivers side inner fender area with some custom brackets. unfortunately I had to eliminate it since the FFM developed a gushing leak. at some point I will put it back with a new FFM.
I found a failing pmd on bumper, they are suspect always, so I try each test with known good pmd. Does anyone know what ecm wire is power, I need to monitor that circuit.I have 2 pmds mounted to bumper with heat sinks, both on harnesses. I tried “extra” new one and plugged in by pump. Nothing.
I have a question for you, you ask this question in other posts. What ecm pin is the power, so I can monitorIs your security light staying on?
