Will L.
Sorry for the loss. My prayers sre with you and your family. It does get easier with time.
I tried to edit last post.....From what I've read the van rear axle is the widest one wheel hub face to wheel hub face. The one I bought for my mud K5 blazer was out of a 2000 or so 3500 van with 4:10s and I think it was 72" WF TO WF (wheel face). I'm also pretty sure my Suburban has the original proportioning valve not the newer updated one mentioned earlier in this thread I believe. And I do believe the front brakes are more of an issue than the rear in my truck anyway. I stood on my brake pedal with both of my size 13 feet pushing as hard as I could and I could feel the ABS go on and off and still pushed a VW Passats LR tailight up to the back window and I think it really should have stopped. No damage to my truck at all. Not sure if the ABS is reacting on and off fast enough, like to much time releasing pressure when it senses a tire skid, I always wondered if it was the 33 inch tires throwing of the calibration even with a new speed buffer to recalibrate the speedo due to the larger tires.
I'll have to look into the ABS calibration, my 94 Burb has a different module than the one on the video. FYI I snagged a 14 bolt 4:10 ratio full floater rear from a 04 GM 2500 yesterday, It measures 68.5" wide which is what the front measurement is on my Suburban. The drum brake rear measures 65.5", so it should make my wheels line up perfectly instead of the rears being set in 1.5' on each side. I was at a U pull today and saw a 2wd 04 front caliper and now I see why the GMT 800 brakes work so much better, the caliper is like twice the size as the one on my GMT400. I also stumbled across a 2000 3500 dually 6.5 that someone obviously wanted the IP, they were nice enough to unbolt the no EGR manifold and dual therm housing and left them laying for me to just pick up and carry to the counter along with the IP gear. It looks like they busted the aluminum IP mount housing with a hammer, I guess they couldn't loosen the IP bolts. Are the later model lower control arms any better than the previous model stamped ones? They look like they may not be as strong, I don't have a problem with rust on my stamped ones.
I would NEVER reccomend what this guy shows in this video. What he is pressing is NOT an air bleed, it's the shuttle valve in the proportioning valve. When he depresses it like that, he is forcing it past MAX travel and forcing fluid out where it was NEVER meant to come out. If you have the ABS bidirectional tool, you can do this the right way WITHOUT destroying the seals inside a NLA proportioning valve.Your larger diameter tires do effect the ABS ability to stop the vehicle as designed and re-calibration of the VSSB does nothing for the ABS however there are tire diameter to brake tables on some GMT400 applications that allow a % change to ABS that change would be the same % difference between the original tire diameter and the newer tire diameter (loaded). Name in carcode is; Tire size brake calibration for GM C/K Truck under 15000 GVW and 03-04 under 8600 with no VSES
Spongy brakes........see;
Thanks for the 'correction' on both topics........."in the name of safety perhaps deleting the video is in order too."I would NEVER reccomend what this guy shows in this video. What he is pressing is NOT an air bleed, it's the shuttle valve in the proportioning valve. When he depresses it like that, he is forcing it past MAX travel and forcing fluid out where it was NEVER meant to come out. If you have the ABS bidirectional tool, you can do this the right way WITHOUT destroying the seals inside a NLA proportioning valve.
And FYI, the gmt-800 trucks do NOT use the corporate 14 bolt full float like ours. They are very similiar, but they are a completely different axle. So keep this in mind when you order parts to be certain to order parts for the correct year axle. Many have adapted the gmt-800 rear discs to the earlier axles. If you have a 3500 srw or SUBURBAN, you have the over the hub design just like the gmt-800 uses. So you can weld on a new plate to the axle to retain the disc backing plate, and bolt disc brakes onto them. I discovered this AFTER I had just replaced EVERYTHING in my drum brakes.
Now that I think about it I need to double check with the lift kit manufacturer to see it I can even install the forged LCAs, the way the lift is set up is there is a subframe that lowers the differential, axles and LCAs 4 inches, then they use different upper CAs with a 4 inch spacer between the knuckle and the upper CA. Since the differential was lowered 4 inch I was able to install the P400 without modifying the oil pan.
