SnowDrift
Ultra Conservative. ULTRA!
Copy that.
Possibility of interference with the inner fenders ?Today I started by making steering gear bolt spacers out of 1/2” ID DOM. Once I was happy with them I welded them to the inside of the frame rail. After that I started working on the boxing plate for the rail. I mostly used masking tape to make it because that was easier for figuring out the holes needed for the spacers.
Then I welded it in.
After that I made the plates for the front frame horns.
View attachment 80214View attachment 80215
I ended today working on the front shock mounts. I had been looking for different ideas since I wouldn’t really be able to use the factory mounts and stumbled on the extended upper mounts that ORD offers. They looked just like the OBS Ford F250/F350 mounts, so I decided to just get a pair of those. After I figured out what I wanted to do, I cut the first one to the length I wanted and then tacked it in place. I’m going to look at it some more tomorrow before I decide it’s exactly what I want.
View attachment 80216View attachment 80217
More than likely. I'll just notch them or add a bulge to them to clear.Possibility of interference with the inner fenders ?
Someone’s gotta keep the Gojo people in business!!Yeah, you would've thought he would at least have squirted them with a can of engine degreaser and powerwashed them by now just to make handling them less messy.
Fast Orange is better!Someone’s gotta keep the Gojo people in business!!![]()
How about a REAL truck air tank designed for the job, like off a wrecked semi?Ya know, making an airtank that is plumbed with QD like your air tools use that comes off to carry over to something is a convenient thing at times. I have a couple aluminum propane tanks that are beyond re certification and cost more to certify than is worth it. So that was the plan for those. Aluminum tank is nice and light.
I was thinking the same thing until I thought about how they were done from the factory - they didn't have any additional reinforcement from the factory, they just relied on the radius formed into the pads to strengthen them. I would have added gussets for additional peace of mind, but the rubber pad wraps all the way around them so I can't do that.I would think as heavy as your probably going to load this truck that those overload pads might need some reinforcement
