n8in8or
Looked at the frame for the first time since painting all day yesterday…..and I do mean ALL day - I started the first coat at 6:15 in the morning and that took 3 hours to apply, second coat was at 1:30 and took 2 hours, the final coat was at 7:30 and only took 1 hour because it was KBS Black Top that only needed to be applied to the surfaces that would see UV. So from 6AM to 8:30PM with some breaks in between. I thought using a brush and roller would be good for this frame since it’s boxed, but there were still a lot of nooks and crannies to deal with - if I was to do it again I would spray it and deal with the extra prep and cleanup associated with that instead of the brush and roller. The paint turned out ok, with the typical runs that I can’t seem to get away from. I think what my problem is with these large projects, and the way this paint flows out, is that there won’t be a run at first, but when I get back to the earlier section I cut in with the brush there is now a run and it’s too late to smooth it out. Guess I won’t be winning any concours shows with this truck….
