Larry
how high of a tempature and how do you crack them.
hank1948 I read a thread earlier where you had machine the head precups out bigger. I didn't see too many other replies about this after the fact and was wondering what ever happened with this? Any power or mileage gains? Kinda curious...
Thanks
I firmly believe that the larger openings allows greater power near peak torque angles, allowing the flame to expand quicker.
This was back in 09, and as I have read the whole thread... what were the results to this? Is the engine still in operation?Taking the camper to the campground friday, so I will post results this weekend
  This image is a prototype to a set of pre cups I installed. They are not hand done as this pre cup was. But this was taken and measured,put on a machine and precision cut so that all eight were the same size. The floor of the pre cup was altered. THIS IS NOT A setup for use,  it has inherent issues with some rpm ranges. so would you say this is a max power only mod?
