3500GMC
What T F, over
.. and you have to believe GM was conservative with just about everything....
That is for sure.
I can't help but think about the battles between the engineers and the bean counters, internally, at a corporation (GM).
On the pre cups, these are essentially our 'combustion chambers' - think gassers here- so they do create the turbulence for a more complete burn. 'Cause we ain't got no combustion chambers or flame pockets in our pistons. :smile5:
With us raising boost levels and using WAY better turbos (read- more overall AIRFLOW) this is adding the turbulence that would allow us to open up the pre cup opening some. The key is keeping them exactly the same cylinder to cylinder. Kinda like CC'ing heads on a hot rod gasser.
The valve reliefs in the 6.5 pistons are just that, I think, reliefs. Valve/piston clearance had to be addressed in some way. Although, these 6.5's valves are perpendicular to the flat of the piston, so this frees up some interference issues and eliminated the need for combustion chambers.
I'm still getting to know the humble 6.5. :thumbsup:
