Problem: Explain your problem in concise language (ie: Cranks but won’t fire). _______running rough and dumping white smoke_____________________
- Year: __1997____
- Truck model and class (ie: c2500) ___2500______
- Automatic or Standard ___auto_______
- Mileage: (indicate miles or km) ___140000kms______
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) _pmd and heat sync new glow plugs new fuel filter__________
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? ___turbo and yes egr___________
- Ambient outside temp: (indicate *C or *F) __10*C________
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc) ___petro canada...not to sure what that would be______
- What fuel additives are you using? ___lucus________
- Where are you located? _____british columbia canada________
- Air filter ______new___
- Fuel filter _new________
- CDR Valve? __unknown_______
- Coolant – last flushed/replaced at ___6mths__________
- Oil – synthetic/regular, changed at __reg every 5000kms_________
- Batteries – state of charge, (matched set) replaced at ___new__________
- Battery cables and grounds (removed, cleaned and tightened): ________check ok______
- Glow Plugs - how many miles on them? ___0 new______ What type? _____ac oem________
- Injectors - last changed at _____unknown__________
- What were you doing when it happened? ____decellerating from 80 -60kms and felt rough running and then noticed the white smoke pouring out of the exhaust__________
- How was the truck running fine before this problem appeared? ________excellent thought i got a steal on the truck cause i just bought it a week before that_____
- Has this problem ever happened before? _____unknown__________________
- Describe any related factors that might be part of the problem. _____n/a_________
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) __Y__ And? ___no codes_____
Diagnostics:
1] Starting:
1a] Does the engine start? ___yes______
1b] Does the engine crank over? __yes______
1c] Are your batteries fully charged? ____yes_____
1d] Have you removed, cleaned, and tightened all battery connections? ____yes____
1e] Does your Wait to Start light come on for a time? How long? ___10seconds______
1f] Does your glow plug light come on? ____yes_____ For how long? _______10seconds__
1g] Do you see smoke from the exhaust while cranking? What color? __no______
1h] Does the Service Engine Light Glow during Start/bulb check? ______no__
2a] Can you hear your lift pump working? _____yes_______
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? ____yes_____
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? ______yes_____
2d] Loosen an injector line and crank the engine - does fuel come out? _______havent tried that__
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? ____yes_______
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) ______intake_____
3b] Condition of Extension harness (if used) Vendor or Homemade? _________
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. _________
3d] PMD Make: ___________
3e] PMD Age: _______brand new______
4] Stalling Issues
4a] Do you experience stalling only when hot? ____no________
4b] Does it stall under particular circumstances? (ie hit bump, or on accel) ___no___
4c] Does pouring cool water over the IP seem to help with restarting? ______n/a___
4d] Is stalling momentary (engine recovers)? ___n/a______
4e] Does SES light come on when engine hiccups? ____no_____
4f] Does cruise control quit working when engine hiccups? ____n/a_______
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? ___unknown____
5b] ny bubbles or oil film in coolant overflow tank? ____no___
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? ____no______
5d] Excessive white smoke from exhaust on cold start? __yes_______
5e] Excessive black smoke from exhaust under hard acceleration? ______no white____
6] Performance Issues
6a] Do you have gauges (boost, EGT) ? _____no______
6b] Maximum boost under load? ___unknown_________
6c] Have you added a performance PCM (reflash) or Chip? _____no_________
6d] Have you changed exhaust / downpipe / crossover? ___no_____________
6e] Wastegate – mechanical or vacuum (OEM)? _____vac oem_________
7a] Single or dual thermostats? _____dual_______
7b] Have you replaced them lately? Manufacturer of replacements? ____no_____
7c] Have you pulled and cleaned Radiator and coolers lately? _______no_____
7d] Have you replaced the fan clutch? Manufacturer of replacement? __no______
7e] (winter) Have you tested your antifreeze? Good to what temp? __________
7f] (winter) Are you using a winter grille cover? ___________
____________the truck was running excellent up until this day. i was slowing down to 60kms from about 80 and started feeling chugging and sluggish throttle and then noticed the white smoke, i stepped on it a bit and got back up to over 90 and seemed to run fine again and no smoke but as soon as i slow down all hell breaks lose again and even worse at idle. no coolant smell new pmd new fuel filter lift pump has been swapped with new one lots of fuel at water in fuel port. cut out the cat thinkin maybe exhaust was plugged and thats not it either. im thinking injector pump but i hope someone can steer me in a cheaper direction than that. thanks to all...i am new on this site but have learned alot from it in the last few days_____________________
- Year: __1997____
Diagnostics:
1] Starting:
3] PMD / IP Issues
4] Stalling Issues
5] Running Issues
