Acesneights1
If you end up pulling it you can always have it bench tested 1st. . Gotta figure out if it's one cylinder causing it first. That will tell the tale.
Jim what do you think about just loosening lines to find the Cylinder ? Tech2 is nice but not always availible. Not sure iof AE or carcode can do cyl kill. I know GMTDScan can but he is OBD2
does it help to narrow it down if it sounds like my exhaust is cracked at the down pipe in regards to intake valve or exhaust valve if that is the case???
yea it is definetly raw fuel. i have read that possible failure of ip will cause the white smoke because of air being in fuel. and to bk95td...thanks for the reply i am so hoping it is not internal.
I was going to ask where you're located so I could offer some assistance if needed.....but seeing you measure distance in km's and not miles that tells me you're too far for my help![]()
