dakota89
is there somebody who can gave me the wirering diagram for the pcm on a 98 3500hd i found that there is a brown with a white stripe was cut from the harness its in the midle plug on the b side and they run another wire going under the dash above clutch in the gray box they must a bypass that brown wire but the gm mech unhook that wire so i dont know where it was plug to a ground or 12v suply but they did put a fuse on the end of the wire going to the gray bax above the cluch so i m assuming a 12v suply and he also unhook it on the pcm harness so my high idle problem must be there i just supose but that white wire a the place of the brown eireand in to the gray bax again to ground or 12v suply if i m right about that wire i think it s the brake signal
