ak diesel driver
6.5 driver
another consideration of putting return fuel in the filler neck would be foaming and or aeration
Tank listings show different part numbers.If I do it it will be adding a 1/2" pickup line to the existing OEM pickup assembly or I was thinking if I could find a real low profile sump assembly and try to put it between the tank and the factory skid plate but it would probably have to be like a 1/2-5/8 profile to try and sandwich it between the tank and the skid plate. Does anyone know if the fuel tank out of like a 2500 gas Suburban 4x4 would be the same as the one in my diesel suburban? Just thinking I could save my tank and bucher a doner tank.
"I maybe missing something here as I suffer from "some-timers" but I transfer fuel from my aux tank exactly into the main tanks fuel fill as I drive for many years now and never ever had such an issue? So why would the small fuel return cause an issue? Lest we forget the fuel gets sloshed around the tank and surely air bubbles do form unless foam or bronze wool are incorporated into the tank like in a fuel cell.BAD IDEA!!! The return has to be submerged in fuel or the fuel system will siphon the fuel back to the tank resulting in hard cold starts after a long overnight sit. The fuel system will be full of air every morning and need to be re-primed. This is why GM spent a nickel on the submerged in tank fuel return hose.
Like I suspected I had a brain fa_t thinking about something entirely different "my BAD!"Checkout posts 16 and 17 in the following thread.
Working on a "next-level" fuel system
I am starting this thread a few weeks before I planned to, but the topic has come up in one of my other threads, so the timing made sense now so the topic could really get explored. In my other thread http://www.thetruckstop.us/forum/threads/going-mechanical-with-a-moose-omega-marine-ip.45204/...www.thetruckstop.us
