I'm not sure who makes those, I was mistaken in my previous post the smaller the micron # the finer the filtration right? I'm told the factory will filter 5 to 7 microns? So the OEM will filter better than the Cat filter I have pictured.
Typically you want to stay under 8 micron for a not so fussy fuel system. Water molecules are 8 microns, so by going smaller, you block water for the most part.
Well if I'm wrong I'm wrong, but that begs the question of some demos I seen before. They took a filter with an absolute micron filtering range of 7 microns, and it stopped all flow once water covered the element at 0 psi. If they put it under pressure, yes water would flow, but at 0 pressure it just sat there.Off on that one, sorry Ferm. The one owner of the plastics to fuel company I worked for, also is on leading edge electronic water filtration and his only competition is the folks at MIT. So he drug me into the water filtering world somewhat.
Measurements are varied on water, so small the scientists argue from 275 picometers to 310 picometers. That larger 310 would be 0.000310 micrometers or microns for short.
The 275 was the standard set well over 100 years ago, but testing at Cambridge put it ata 282 about a decade ago and the latest MIT testing shows the size actually changes based on temperature- something that is scaring the nano scientists because it may expand more than it vibrates- something that argues with E=MC2 so they all want to quit researching water filtration hoping to find Einstein'smissing link in the size drop. But since people are dying, they continue the filtration issue for now.
Anyways, think of this one- the factory filters are 5 micron, but they are rated “nominal” not absolute. Their absolute ratings are in the 20 range for AC Delco, not sure on others. If the factory filter stopped it all, we couldn’t have watched BigT have his water in injection pump issues a while back, right?
But you can buy 1 micron absolute fiters for your drinking water at home from many companies. If they are absolute at 1 micron, that means no water would ever come out of your filter. Almost every virus is less than 1/10 micron, and they can all be filtered out of water. Taking bacteria and virus out isn’t even a challenge since the 1980’s. Heavy metal particals are the #1 problem in 3rd world countries water supplies. Even here- Lead is 175 pico- Who here is from Illinois? Still drinking bottled water, right?
Nice. I too am going to go to a return-style external regulator. It should take some load off of my current lift pump and hopefully help it keep up with my IP. I also like the idea of the pump not continually recirculating the fuel internally and adding heat to it. I look forward to seeing what you come up with. I will be starting a thread on at least the fuel tank portions of mine in the next few weeks since I decided to do the tank upgrade while it's out for my rust repair project.Ok guys thanks for the replies on the fuel filters, keep em coming. Like I said earlier I am taking this time to get my IP pump modified or purchase a new one while repairing a valve cover leak. Also I am trying to upgrade my entire fuel system with a pressure regulator with a tank return line possibly, along with oil filtration and hopefully a pre oiler pump system. Below is a link to my P400 build over on the Diesel Place with alot more info and photos than on this site. As of this point I will be attempting to posting the rest of my build here.
https://www.dieselplace.com/forum/6...e-modifications/552722-p400-burb-install.html
... the the addition of a dedicated return line which requires dropping the fuel tank.
A direct return line to the fuel tank could be plumbed into the fuel filler neck such as the set up Air Dog markets. Save you from a tank drop anyway. Air Dog uses an adapter that requires the rubber fuel neck to be shortened by 1" but, you're talented and a means to make the system work another way could be sorted out.
BAD IDEA!!! The return has to be submerged in fuel or the fuel system will siphon the fuel back to the tank resulting in hard cold starts after a long overnight sit. The fuel system will be full of air every morning and need to be re-primed. This is why GM spent a nickel on the submerged in tank fuel return hose.
