Now that I think about it GM would most likely have stamped out a new firewall. It would have been alot of work to retrofit one.
So you can now get a P400 with oil pan to fit into a 4x4 truck from the factory?
What is the oil pan like? How many qts of oil does it hold?
sure it is possible, but why? the center mount is a 2.5" Cast outlet for the exhaust, and there are not alot (read none) aftermarket turbo upgrades for the center-mount system... penn. uses a center mount, but it is a totally different animal..... the only advantage to it is it made the best numbers for the 6.5l (because of quick moving, equally balanced exhaust) for me, it is not enough of a gain to warrant the work invovled... maybe just the cool factor...Only pic I can find of the Holden's firewall:
Good luck finding another. Apparently, there were only about 400-500 Holden 6.5 Suburbans made over the entirety of the GMT400 model years. I know a guy on a couple other forums that goes by the screen name Hquick (howard). He's an Aussie and has a Holden suburban, albeit a gasser. He might be able to get better pics of a Holden Suburban firewall.
If you've reworking things like the heater box for RH drive, a bit of firewall massaging isn't that big of a deal. I could do it in a couple hours in the garage with the MIG and some shears. It's no where near as hard as people make it out to be. The big question is how far you have to get into the HVAC component's space. Then again, they may have cast a special lower manifold to move the whole thing forward. Who knows what you'll see when you're dealing with non North American vehicles....
Leroy; I'm willing to bet the ducts are where they are because they used an s-10 blazer dash instead of a GMT 400. That's where they are on an s-10 IIRC....
It has about 40k on it and I'm planning on opening it up after I get it home
Is the oil pan the same/as much of a problem in a 2WD also?
When we measured with the metal hummer pan in GMT400 2wd, it was missing less than an inch. Would need to go 1 1/2-2" to have clearance to allow motor mount movement and wear....
