Big T
I have a friend who is shop manager for a refinery pipeline company who welded mine. Can’t tell you about the process.No one in town wants to weld this.
I have aluminum stick rod and have played with aluminum soldering but I think it would be better to grind away on the weaker side so when the bolt is torqued it would apply pressure to the stronger portion of the manifold.
Any suggestions ? ? ? ?
There should be a ton of these lowers available. You can install this as is and run it while searching for a new one.
My experience you crack them torquing them down over a wire that slips under the manifold. This is where feel comes into play when tightening. If there is a wire under it the final portion of the torquing process will squish down. Without a wire, it hits hard and hits torque level quickly.
