Steak&Eggs
Active Member
Thanks for the responses!
I could not find the 'peeing' unit - I even looked in the AC/Delco's that I removed from the engine... it must have been on one I did not record - I usually give a pump or two to fill up with fuel but don't record that part.
I noticed none of the AC units chattered, will that affect mileage? They ran fine but if cool they would puff some smoke the first start in the morning. 10 mpg is the pitts should get 16.
I changed my test setup some, we should be able to see a little better. I did notice the radio comes in loud when played from a web page.... and I have to turn it down on every video. I should have turned it off instead of lowering the volume. Drat.
So - What do you think the chances are that these will work like the originals?
