M123KT-450
- Messages
- 442
- Reaction score
- 0
Yea that is not my concern the issue i am having is this oil leakage:
You have the improper clamp on that intake tube and that CDR oil is blowing out when boost is created. You need that Spring Clamp.
I let some fuel sit out for a few weeks, and it was so super clean crystal clear it looked flawless. If your fuel is cloudy, then thats probably your problem, get it out, clean the tank up and put in fresh diesel.
EDIT: I now see the other clamp. You sure those are tight? Is that where that oil is seeping out of?
http://www.dieseltowingresource.com/showthread.php?t=6912&highlight=cloudy+fuel
Check that thread out about someone who got a bad batch of fuel and screwed him all up. Reminds me of your story.
Not a rebuild, just a calibration resistor for shops with high tech equipment that can command a fuel rate and measure actual fuel squirted by IP. When its off they put in a resistor to make it correct. So a resistor value may decrease fuel (1-4) or increase fuel (5-9). I have pics at home can post later.
wrote this back in post 72....
You might check what resistor value is inside your PMD connector, its a little Printed Circuit board the shape of the connector that sits at the back. When ordering a new PMD you can increase power a little with a #9 resistor (ordered separately $26) if you have a #5 now. A higher resistance value increases the fuel output above what the PCM commands. Or at your risk could put in a $5 potentiometer across a couple of the lines and dial in your own resistance until it throws codes.
