bison
ACE,it is hard to tell from here if the sinc rings are worn but as long as they don't bottom out against the gears i think they're OK.
The loose nut on the output shaft causes all kinds of problems.
Friend of mine had a vibration(more like a drone) and a hard shift in first in his 94 chevy 3500 6.5 NV 4500.
turned out the 5th gear nut was loose
Tranny shop welded the nut to the shaft after torqueing ,(not to smart i think) but it solved the drone and the hard shift.
