88gmctruck
02GMCtruck
They are the same fluid.
Suppose it depends on what forum. In the 6.2 Forum at Dp OBS is square and NBS is 88+(except for K5 and K30). Think it ended up that way because 6.2s were in both body styles.Uh, I think you have things mixed up on OBS and NBS. Traditionally OBS = 88-98 and NBS = 99-06, but there are many years of overlap.
it's better to use the GM platform designations as it accurately describes the truck independent of the year:
Squarebody: 73-91
GMT400: 88-02
GMT800: 99-07
GMT900: 07-Current
Anyway, I'm assuming you are talking about the NBS truck as your 93 right? The trans is pretty darn easy to get out IMO. The trans tunnel doesn't unbolt however, like the older squarebodies. The trans can come out without removing the torsion bars, however it's much easier with them and their crossmember removed. You can easily remove the torsion bars by jacking up on the lower A arm, removing the adjuster bolt and crossbar, then slowly lowing the torsion bar pressure by lowering the jack.
My 86 is a K30. K and c was used since the 70's on pickups and Blazers.Oh, and any squarebody vehicle 88-91 used the designations R and V (2wd and 4wd) while the new GMT400 trucks used the C and K. Those were weren't just limited to blazer/jimmy and 1-ton trucks, There were still 1/2ton, 3/4ton in the suburbans so the R-V designation carried all three weight ratings.
Only if you rebuild yours first and do a good write up...I'm scared...:rof:Where can you get a rebuild kit for an NV4500, it doesnt look like 4wheeloffroad has one, just the manuals. I have a tranny with atleast 2 synchros gone for 2nd and 3rd and want to get it fixed. Its in my 94 so low 1st and rev IIRC
I dont mean to hijack the thread but it pertains to your problems if you have to rebuild like you are thinking.
I got one sitting here,good tranny,just needs the input shaft tip welded up and turned back to size.Tell ya this, used NV4500's are extinct right now. The only way to get one is buy a reman and eat the core which is pretty hefty. Dodge ones seem to be abundant. wonder what the differences are.
