i did a history search on this truck at the dealer, apparently they rebuild the front axle a couple years ago.( prob had a 1 st year apprentice do it :rolleyes5:.Still shaking my head about loose front axle assembly case bolts. ..
Sent from my SCH-I535
I did pull the lever in M but pushing the up and down buttons don't seem to have an effectcan you at least pull the lever to "M" and select the gears?
It ain't burned out. i pushed te button underneath it once and the indicator lighted up bright,..but it happened only once:???:It's unusual for the indicator to burn out as it is an LED, but it can happen.
So does the tow/haul work?
Sent from my Studio 5.0s using Tapatalk
