bison
I cut a 1/4" flat washer so it was open on one side, welded a welding rod on top. Slip it on the button and pull up.
More than 1 way to skin a cat eh
You're a good man,.Thanks JeffI sent them both to you. :thumbsup:
That'll work yes, but asking on the site gives me a chance to interact with you folks,...i gets sometimes lonely being by myself in the bush :hihi:Here's a tip...
go to your google search box in your browser(assuming google is your default search engine)
type in your search terms: for example: LBZ glow plug replacement site:thetruckstop.us and click the search button(you can insert any of your own search terms in place of LBZ Glow Plug Replacement)
this is the result you will see from that search LINK
here are some of the search results in that link: (notice that all of the search results are for thetruckstop.us you can search any forum that way by changing the name of the website behind "site:" )
- LBZ Glow Plug Replacement - The Truck Stop
www.thetruckstop.us › ... › Maintenance & Fuels
Mar 19, 2010 - 15 posts - 5 authors
It started throwing P0676 out of the blue one morning which indicates that the glow plug on the #6 cyl is open. The last digit in the code ...- LBZ Glow Plug - The Truck Stop
www.thetruckstop.us › ... › GM Duramax Engines › 06-07 LLY/LBZ
Jul 1, 2009 - 15 posts - 4 authors
The "driveability" tech at the local dealer says they only have replaced the "bad glow plug" in the past without a problem. Not all 8 as the tSB ...- 06 LBZ - Check Engine Light, Code P0667 - The Truck Stop
Jun 14, 2011 - 15 posts - 1 author
I found this Tech Bulletin about the LBZ glowplugs. It is looking like at a minimum I will need to replace all 8 glow plugs. Someone told me that ...- lbz glow plug questions - The Truck Stop
Sep 8, 2010 - 15 posts - 7 authors
I thought the dealers were replacing all glow plugs when one went bad now.If I can fix this problem by just replacing one (#8) myself id rather ...- Glow Plug relay - The Truck Stop
www.thetruckstop.us › ... › GM Duramax Engines › 01-04 LB7
Jan 25, 2012 - 15 posts - 2 authors
This is on the 04.5+ glow plugs, LB7's used a regular 12 volt plug. Another reason why we need to know what you have to tell you how to test it.- Glow Plug Replacement for 2006 FORD - The Truck Stop
www.thetruckstop.us › Forum › Engine Discussions › All Other Diesels
Dec 17, 2011 - 3 posts - 1 author
We are probably going to change ours, i tried looking at the engine without ... Cylinder 6 glow plug circuit fault ... LBZ Glow Plug Replacement.- LBZ Code P0678 Glow Plug Controller Error - The Truck Stop
Jan 1, 2014 - 15 posts - 1 author
I had the glow plugs go one at a time. I eventually bought 8 new ones and replaced them all, and kept the others that were still good for any ...- Glow plug tricks - The Truck Stop
www.thetruckstop.us › ... › GM 6.5 Diesel Engines
Sep 17, 2009 - 15 posts - 11 authors
Anyone have any good tricks for removing swollen glow plugs? ... 06 Chevy 2500HD LBZ Duramax LT3, tinted windows, 265/75/16 tires, Redline LED brake ... OTC removal tool link http://www.mytoolstore.com/otc/6005.html- glow plug replacement question - The Truck Stop
Sep 30, 2011 - 15 posts - 9 authors
i have a 1995 engine code f, i want to replce the glow plugs, with winter coming up. i was thinking ac ... I highly recommend the glow plug relay mod that is listed some where in the library. ..... LBZ Glow Plug Replacement.- Help please i think i have a glow plug problem - The Truck Stop
May 31, 2011 - 15 posts - 5 authors
I replaced my glow plugs sunday afternoon didnt have any trouble. ... fuel filter was replaced 1000 miles ago. does anyone have any ideal what the problem might be. ... LB7 Glow Plug Controller and Glow Plugs Removal.
