O7 Dmax your thoughts
I didnt think the dmax had the glow plug swelling issue. Mine are still original at 235k.
source unknown
They don't, but it is still a steel glow plug into an aluminum head so corrosion is always an issue. And some break off due to severe rust going all the way through the glow plug.
I bought a LBZ turbo from an guy just north of me that had 100,000 miles on it, it came out of his truck that he said a glowplug had broken off and destroyed the motor. Some things do happen and I think his was just one of those rare occurrences. Same with a glow plug welding itself in the hole.
06LLY's and early LBZ's had a recall for the glow plug controller keeping the plugs on for to long, and it would cause them to break off and go through the engine. Most all of them got reprogrammed under the recall, but a few have slipped through. And of course, sometimes crap happens.
I was going to remove both tires and take a look at the brakes and R&R the glow plugs. My 2 ton floor jack sprung a leak, so I just grabbed the trusty milk crate sat on it pulled the liners and crawled in.
You won't enjoy replacing a fan belt either.
I found out why this one is so hard to change. It has an air shut off (ex oilfield), after sitting for a few weeks it wouldn't start. I must have bumped the switch. The device makes for little room around the tensioner area.
I pulled the pass side batt and thatta there glow plug was right there smiling at me in plain sight :D, i bet i can get at all four from above :agreed:,... no need to pull the liner on this side;)
Fan belt replacement looks to be a wee bit more complicated, can i loose that Amish buggy wheel fan guard ?, it looks like it ain't serving any other purpose than to be in the way!
Mine has been hanging on the shop wall for a couple of years with no temperature problem as a result
Sent from my SCH-I535
I live in Phoenix Az. and would never consider removing the Amish looking buggy wheel on mine. Bad enough you have a 10lbs. motor on a 5lbs doghouse and you can probably get away with it where you live. These trucks are DOGS during the summer in town on the freeway at 110*f after a couple hours driving with in town stop and go the being the worst.
The only thing I removed to replace the serpentine belt was the intake and manipulated the belt into place, of course a third arm would have been helpful
If I lived in the valley I'd leave mine on too. My son lived there for 7 years so I'm pretty familiar with the conditions. I wouldn't want to live there year round.
How in the blazes does one get to the 2 push pins holding the fan shroud halves together on the pass side without removing the air filter housing??.. special tool again??
What the F happened to the tried and proven bolts that used to be there?? ....jeez!
Push pin type same as the fender liners, had to remove the intake also. I also found when I did the R&R on the glow plugs I had to keep the wire from tightening up against the head. Lisle tensioner unloader tool is helpful for the belt replacement.
I'm used to my 82 and bolts and nuts, well not anymore on this truck. For me on this truck I'm about half tempted to drill a hole in every tool that comes near this truck so I can tie a string to it in case I drop it. They drop in some of most F-ed places. Had a nut driver slip out my hit the fan, bounced and landed between the shroud and radiator.
Air filter box pulls right up and out real easy. Remove the top, pull the element and pull the box straight up out of the rubber grommets. Spend a bunch of time reading and looking at pics and DIYs and most of the maint questions are in there somewhere as well as a bunch of pics of how things are put together.
I found that out already ;)
Much easier to ask then to root trough the archives,..i usually can't find what i'am looking for anyway.:D
I wasn't about to dismantle half the truck for these 2 damn pins :nonod:
I fabbed a pull up tool out of a piece of thin wall angle iron, i cut one side back a bit and folded the other side over against and spot welded it to form a closed corner so it has some strength and then cut a slot with a zip disc in the corner to accept the pin head.,...took all of 5 min to make and another 3 sec to hook under the heads and pull the pins.;)
There gonna be 2 bolts in there come put together time.:agreed:
I cut a 1/4" flat washer so it was open on one side, welded a welding rod on top. Slip it on the button and pull up.
Here's a tip...
go to your google search box in your browser(assuming google is your default search engine)
type in your search terms: for example: LBZ glow plug replacement site:thetruckstop.us and click the search button(you can insert any of your own search terms in place of LBZ Glow Plug Replacement)
this is the result you will see from that search LINK
here are some of the search results in that link: (notice that all of the search results are for thetruckstop.us you can search any forum that way by changing the name of the website behind "site:" )
  1. LBZ Glow Plug Replacement - The Truck Stop
    www.thetruckstop.us › ... › Maintenance & Fuels
    Mar 19, 2010 - 15 posts - ‎5 authors
    It started throwing P0676 out of the blue one morning which indicates that the glow plug on the #6 cyl is open. The last digit in the code ...
  2. LBZ Glow Plug - The Truck Stop
    www.thetruckstop.us › ... › GM Duramax Engines06-07 LLY/LBZ
    Jul 1, 2009 - 15 posts - ‎4 authors
    The "driveability" tech at the local dealer says they only have replaced the "bad glow plug" in the past without a problem. Not all 8 as the tSB ...
  3. 06 LBZ - Check Engine Light, Code P0667 - The Truck Stop
    Jun 14, 2011 - 15 posts - ‎1 author
    I found this Tech Bulletin about the LBZ glowplugs. It is looking like at a minimum I will need to replace all 8 glow plugs. Someone told me that ...
  4. lbz glow plug questions - The Truck Stop
    Sep 8, 2010 - 15 posts - ‎7 authors
    I thought the dealers were replacing all glow plugs when one went bad now.If I can fix this problem by just replacing one (#8) myself id rather ...
  5. Glow Plug relay - The Truck Stop
    www.thetruckstop.us › ... › GM Duramax Engines01-04 LB7
    Jan 25, 2012 - 15 posts - ‎2 authors
    This is on the 04.5+ glow plugs, LB7's used a regular 12 volt plug. Another reason why we need to know what you have to tell you how to test it.
  6. Glow Plug Replacement for 2006 FORD - The Truck Stop
    www.thetruckstop.usForumEngine DiscussionsAll Other Diesels
    Dec 17, 2011 - 3 posts - ‎1 author
    We are probably going to change ours, i tried looking at the engine without ... Cylinder 6 glow plug circuit fault ... LBZ Glow Plug Replacement.
  7. LBZ Code P0678 Glow Plug Controller Error - The Truck Stop
    Jan 1, 2014 - 15 posts - ‎1 author
    I had the glow plugs go one at a time. I eventually bought 8 new ones and replaced them all, and kept the others that were still good for any ...
  8. Glow plug tricks - The Truck Stop
    www.thetruckstop.us › ... › GM 6.5 Diesel Engines
    Sep 17, 2009 - 15 posts - ‎11 authors
    Anyone have any good tricks for removing swollen glow plugs? ... 06 Chevy 2500HD LBZ Duramax LT3, tinted windows, 265/75/16 tires, Redline LED brake ... OTC removal tool link http://www.mytoolstore.com/otc/6005.html
  9. glow plug replacement question - The Truck Stop
    Sep 30, 2011 - 15 posts - ‎9 authors
    i have a 1995 engine code f, i want to replce the glow plugs, with winter coming up. i was thinking ac ... I highly recommend the glow plug relay mod that is listed some where in the library. ..... LBZ Glow Plug Replacement.
  10. Help please i think i have a glow plug problem - The Truck Stop
    May 31, 2011 - 15 posts - ‎5 authors
    I replaced my glow plugs sunday afternoon didnt have any trouble. ... fuel filter was replaced 1000 miles ago. does anyone have any ideal what the problem might be. ... LB7 Glow Plug Controller and Glow Plugs Removal.
Wow! Great info! Never used goople search that way!
I do it all the time for other sites I don't want to join. Most forums make you join before you can search them, but with google I can search them without joining and find what I was looking for.
