dbrannon79
I'm getting there!
so with that said I can safely scout out a 14cm hx35 for when I get to finish up this 6.2 and it will be happier I take it?
I was thinking that the smaller engine have to have the rpms up to get any effect on that turbo.
personally I don't like the rpm to be up above 2500 on the freeway for an extended time. just one reason I still keep it under 65 even now since installing the 3.73 gears. it seems to like 21-2200ish cruising.
what about port matching with the intake, exhaust, and turbo mounting. Ive seen some youtube videos where they grind and smooth out the mount areas to match each others mating surfaces. is there any benefit to this? not actually "porting" the heads but just opening the areas and smoothing them iirc the videos I have seen did them about an inch or so into the ports from both sides.
I'm just gathering ideas and thoughts as I make a "to do list" when I actually start on it. Balancing the assembly is on the list. along with hoping I can convert it to mechanical finding a not to expensive trans controller.
