JayTheCPA
You have an issue if you have 195 thermostats and it never gets over 170 on a decently long drive.
Definitely not disputing. At the same time am seeing similar observations from others whom just cleaned their cooling stacks, updated the fan & clutch, and switched to waterless coolant. ECT (as reported by the ECM) quickly gets to 170* F and eventually creeps over 170* F, but it takes a while. At first I was tempted to pull the thermostats out for a boil test in a pot, but then observed that warm-up temps were pretty much normal (specifically, the coolant quickly comes up to temp), so decided to leave them alone for now.
For a more robust picture, the Burb's ECM did show ~195* F when outside temps were ~100* F with the A/C 'On' (not towing).
Interesting observation is that the dash gauge will indicate ~180* F while the ECM reports ~170* F. With the 599 block, the sending units were typically within 5* F of each other during warm-up and then nearly equal when warm. With the P-400 and other mods, I am getting a consistently wider gap which does not close.
Presuming both temperature sending units are working normally, am curious as to whether the Burb's current cooling setup is simply that much better than OE and how much of a role the P-400 plays into the equation.
