Ok so here's a list of things to check and verify before we deem parts bad.
@Glagulator @ak diesel driver @Paveltolz help me out here on other things he need to check while he has the intake off.
1. pull intake and verify injector lines are in the correct order (check firing order)
2. inspect wire harness for any problems along with making sure all connectors are secure and no corrosion.
Check, check, and double check. Injector lines are installed correctly. Wiring and connectors look great. Grounds were a little iffy, but I cleaned those up.
No change in the way it runs. Same MO. Runs like garbage with the OS connected and smooths out to normal with the OS disconnected.
Are the IP codes still present?
Post 39, timing is correct at 3.5.
Did you perform a “Time Set” function with the scan tool after getting the motor temp up to 170. Engine will slightly stumble during the “handshake” with the PCM and new IP. Then go after TDCO.
If the gauge arrived, what’s the fuel pressure look like; steady or fluctuating which may be causing issues internally for the transfer pump.
Don’t know what the mice issues are in Nome but, any sign of rodents getting in and chewing wires?
On Edit: straw clutching now.
Anything in the airbox, mouse nest?
The only other thing I can think of is fuel, how old. Lack of cetain(sp) or over abundance of water…
Yes, IP codes came back. We performed the "time set" above 170 degrees, cleared the codes, and the IP codes came back after that.
Yes, timing is set correctly.
They sent the wrong gauge and we haven't been able to find another one, so I'm not sure about the lift pump pressure. Just looking at the stream it produces, it looks good and strong. Not that that means a whole lot, but...
Yes, there are rodents, but they don't really bother wiring and stuff like that. They have way too many other things to eat. That said, I did look and I haven't seen any signs of them doing any damage.
Airbox is clear.
No water in the fuel. Fuel is good. That was the first thing we checked when we got here.
Also: Sniff test to see if it smells like gasoline.
I was wondering that too, but nope. All good, no gasoline.
Once again, I can't thank all of you enough. I know I haven't replied to each and every post that people have made, but I've read every one of them and I appreciate every single one of your responses and your willingness to help.
