JayTheCPA
Also I have a pretty bad cross pipe leak if that could be adding to the problem. I have a new one but don't wanna waste my time on it if I can't get her to run rite anyways.
Leaking crossover probably is not affecting the heat related issue, but definitely want to fix it as a leaky exhaust does effect efficiency in a *big* way.
And the truck has red fuel in it rite now because I left my truck at my dads house last week and he fueled it up with fuel from work if that could be part of my problem also.
Maybe, but not convinced.
Quick searching on P0251 tends to give mixed results that focus on the IP's optic sensor, air in the fuel (which apparently confuses the optic sensor), or insufficient pre-heat (glow plug time) during start as reasons the ECM sets the P0251.
