Aaron1505
Fuel comes out of the water drain while truck is idling not when truck is off and lift pump is running
Of course, fuel will not come out when the truck is not running.
I'm Sorry but that just sounds completely wrong to me. He stated that fuel would not come out with the lift pump running and the truck off, if I understood correctly. From what I understand he had fuel out the bleeder valve with the truck not running but the lift pump jumpered. I do not understand how it could be possible to get fuel out of the drain T with the truck running - without the truck dieing and not get fuel out the drain T with just the lift pump running and fuel coming out the fuel filter bleeder. Sounds like I need to be set straight on what exactly is going on.
LP running and there is no fuel, then you have to check the lines.
May be it has a leak somewhere.
The fuel lines are rubber going under the intake and they are old and brittle.
I'm confused. Believe it or not!
Where would u start diagnosing the 0370 code? The batt cables were new last year and dosent feel like any bulges in the cables. All stainless connectors on 1 year old batts
Yeah, stainless steel is a horrible conductor compared to copper, aluminum, or even zinc. I suggest rethinking those connectors. They are very resistive, and promote electrolisys pretty bad, which starts a bad cycle. Copper has a conductivity of just over 400 W/m.k and the best stainless is like 16 to as low as 12 depending on metalurgy.
