Classified
- Messages
- 88
- Reaction score
- 0
the solenoid is under a cover? I thought it was just right on top, you unscrew it and thats it. Maybe im not following you correctly
As fopr testing injectors, who can do that? and is it ok to just replace bad injectors with new ones? or do you get them rebuilt?
Also, I see alot of people recommend heath diesel but im trying to keep this as cheap as possible and ssdiesel has way cheaper prices. is there a reason for that? Much of thier pricing is 30-40% cheaper than HDP. The IP that ss sells is $700 versus HDP at $1900. Thats a HUGE difference. I dont need this truck to last forever, a good 2-3 years would be great, after that it will just be a backup truck.
The diesel fuel in the tank is a couple months old but it acts no different in the summer when it gets used every day.
Its not audible over the engine, and only audible to me when its building pressure because my IP shuts off, so its already filled the filter assembly and all the lines so it gets noisy. I only ever hear mine when engine shuts off and the OPS is still powering it because oil pressure is still above 4psi for about 10 seconds.
The way you have it seems OK, but you dont have the benefit of the safety OPS feature. If you roll the truck nothing will stop fuel from pumping unless you can turn the key off. Since you know where the LP is, you can just touch it to see if its vibrating, humming quietly while engine is running. Then cut the ignition line you put to the relay and see if it keeps going, that would mean the OPS is working.
If you can hear it, you should be getting fuel, Doug. Wiring the LP to the ignition is not that good an idea... if you get in an accident, the OPS is designed to shut down your fuel pump when the engine quits so you don't keep pumping fuel on the fire. I would put the wiring back, were I you.
Then, put the truck in gear and have somebody turn the key to the start position... it won't crank over (not in neutral) but the LP should start pumping.
You can take the drain hose off the T-valve and put a gauge on that nipple... you should have 4-8 psi on that when idling, and even under wide open throttle (when driving) the pressure should never get to zero.
Jim
The OPS is wired directly to the LP. The OPS is a relay, triggered by oil pressure over 4psi. The OPS is under the GP relay/controller. It should have an orange wire battery source and the output to the LP is grey.
I dont think an ignition soucre to the relay is a bad idea, since its that way in 96+ for this hard start specific reason. However you want it to change to the OPS after its running. Thats why a dash switch would be good. You might want to make sure that purple and white wire you cut is covered because there will be voltage when cranking.
And yes, if the LP stops when you cut the IGN line to the LP relay then the OPS is likely bad.
Not zactly Buddy, time to hit the GM manual some more; IGN is not what turns on lift in 96+ (it begins the logic process monitored by the PCM);and never a good idea to have ign on being the controller, listen to Jim he knows of what he speaks.
OPS is not a relay, it is sort of like one, OPS is a switch closed with oil pressure to close contactor and complete the path of trons to the lift pump, a relay uses a electrical coil that when energized from control signal closes load side contactors, sending high curent trons to the device needing the them.
